Not to be confused with the clutch interlock switch closest to firewall. I read in the FSM starting in 95 the clutch pedal power steering switch on NAs, which is the black connector to the left of the ASCD cancel switch at the top-back of the clutch pedal was removed in that year. In the FSM it was replaced with an aptly named "Clutch Switch." In the connector layout it calls it a Clutch Pedal Position Switch, which is often mixed up with an interlock switch. Does anyone know what the clutch pedal position switch does on the 95-96 NAs? As well as the power steering switch on earlier NAs?
